ProjeQtOr free project management software - Monitoring of re-evaluated load drift - ProjeQtOr
19 Oct 2020 11:54 #1 by QUANTAMEDICAL
We have set up alerts relating to excess loads, but would like to be able to access the evolution of this drift over time. Indeed, when the thresholds are exceeded, there are no more alerts and the history of a task does not contain any record relating to the update of the remainder (or re-evaluated) of a task. Would you have something to suggest to us in order to trace the history of the remaining updates submitted by the person in charge via the imputations (For example: J1 +0.25, J5: +0.5 ...)
Thanks,
QUANTA MEDICAL
22 Oct 2020 14:37 #2 by babynus
There is no specific "history" for these values.
But you can see the changes if you activate option to show history for work data (hidden by defaut to avoid too many lines)
26 Oct 2020 09:05 #3 by QUANTAMEDICAL
Hello, This is an interesting option, I couldn't find it, could you tell me where I can find it
thank you,
28 Oct 2020 15:21 #4 by babynus
On the History Pop-up, you have (when available) a "sow work" button on top left of pop-up.
Or you can select user paramerter "show history" to "Yes, with work"
