ProjeQtOr free project management software - Milstone between two project - ProjeQtOr
18 Sep 2020 17:02 #1 by sa
I have two projects that use the same library. The first modifies and adds new features that will be used by the second project.
The two projects have different teams; the client and the sponosr are different.
Can I refer / link the milestone of the first project in the second project?
I searched in ProjeQtor and could not find to add the same milestone in two different projects.
Do you have a solution and / or a way to do it?
Best regards
18 Sep 2020 17:26 #2 by alainforma
Hi
You can refer and or link a milestone from a project to another one ONLY if you have visibility and right on BOTH
