ProjeQtOr free project management software - Dispatch/Start Work buttons not visible in a Ticket - ProjeQtOr
03 Sep 2020 14:53 - 03 Sep 2020 14:57 #1 by robb1976
I have an issue with Dispatch/Start Work buttons on tickets for Project Manager role. Admin sees them and can dispatch work on tickets but I would like users with limited rights to do the same.
So I have ticket number XXX and Admin sees Dispatch/Start Work buttons and Project Manager does not.
Can you please help me identify which Settings are responsible for hidding Dispatch/Start Work buttons on tickets?
It is self hosted v8.5.3, has worked fine for the last several years but I have cut priviliges for users and buttons are gone...
Last edit: 03 Sep 2020 14:57 by robb1976.
05 Sep 2020 11:42 #2 by babynus
Dispatch is not displayed if user does not have write right on "real work" field (as dispatch will change real work)
Dispatch and Start are not displayed if ticket is in readonly mode (closed or user don't have write rights).
08 Sep 2020 14:47 #3 by robb1976
Hi Babynus,
Many thanks for the hint. However I cannot locate where to set write right on "real work" field...
My test user is a Project Manager with a ticket "in progress". This user is set as "responsible" for this ticket
For Project Manager:
Access to forms: all is checked in WORK and FOLLOW-UP
Access to data (project dependant) : Manager+ set in 1st section and WORK
Still admin can see dispatch and PM cannot...
Robert
10 Sep 2020 15:54 - 10 Sep 2020 15:55 #4 by babynus
Have a look at "specific access"
Last edit: 10 Sep 2020 15:55 by babynus.
The following user(s) said Thank You: robb1976
10 Sep 2020 22:45 #5 by robb1976
Babynus, you are my hero!!!!!! I will suport your project financially. Many thanks again.
Frontend is oldschool but backend is a state-of-the-art. Keep on rolling!
11 Sep 2020 09:13 - 11 Sep 2020 09:13 #6 by babynus
Hi Robb,
Thanks for your comments and your support proposale.
We know about it.
We're planning changes on this side for the end of the year, if God and Coronavis let us do it ;)
Last edit: 11 Sep 2020 09:13 by babynus.
