ProjeQtOr free project management software - [SOLVED] Is it possible to restart the numbering for WBS for each project? - ProjeQtOr
25 Aug 2020 01:41 #1 by codecanvas
I came across ProjeQtOr and currently evaluating it. So far I love the functionality the application provides, great work!
I would like to know if we can keep the WBS specific to the project. For example if I have 3 projects for 3 different clients, I don't want the 2nd and 3rd clients WBS number to start with 2.x and 3.x. Since each will have their own set of WBS, I think it makes sense to keep WBS numbering compartmentalised to each project. It would be great if we have an option to always start each project's WBS with 1.x...
If there is already an option to do this, then kindly point me to the correct settings. I searched but was not able to find any settings for the same.
Thank you!
25 Aug 2020 18:39 #2 by babynus
This is not possible.
Numbering is always absolute. You cannot get a "relative WBS".
NB : WBS must be unique, so you cannot have several levels starting with 1.
