ProjeQtOr free project management software - Projeqor-v-8.5.3 installation problem - ProjeQtOr
05 Aug 2020 14:19 #1 by LeBeauNed
Hello, I'am a new user of projektor ;)
I' m trying to install projeqtor V8.5.3 on ubuntu server 18.04 (Apache2 – PHP7.2 - MySQL5),
After configuration screen completed, only ERROR : An error occurred on ... is displayed.
Please note that I have executed the following commands :
sudo chown -R www-data: /var/www/html/projeqtor/
sudo chmod -R 755 /var/www/html/projeqtor/
moreover, nothing is displayed in the files log ...
My DB projeqtor is in utf8_general_ci
Thanks in advance
11 Aug 2020 17:09 #2 by babynus
To identify the error, we'll have to get the error message.
1) in parameters.php (saved at location you defined in config form), change logLevel
$logLevel=3;
2) check for errors in apache error file, in php error file, in mysql error file and in projeqtor log file
