ProjeQtOr free project management software - workflow and authorisation and customization module add in - ProjeQtOr
31 Jul 2020 17:36 #1 by GIROUXC
Hi
the customization module isn't doing what I expected it to do. I want the rights to adapt to the workflow as defined in the "Section Authorization to change from a status to another" according to the profiles. This is not possible with the "add in customization", we must remove the rights to everyone, even to the admin. Example: I want an operator to be able to enter a new status ticket. As soon as the status changes to assigned, the operator can no longer modify it. But other profiles must be able to work with it. this is not what I can customize the statuses, we do it for all the profiles. If I remove the rights I have to do it for all profiles without distinction. The workflow therefore remains useless to manage the progress of the ticket and the rights and it remains a status list that has no impact on the progress of the ticket.
I hope I have clearly expressed my need.
Do you have a solution to do what I want to do?
Thank you
07 Aug 2020 11:19 #2 by babynus
The plugin cannot manage rights for profile and status. It can manage rights for profile or status.
What you expect does not exist exactly, but possibly Ticket Simple can cover the need.
You give to the operator access rights to Ticket Simple only, that only have few updatable fields, and possibly lock them when status is "assigned" and over.
User who will treat the tickets will then manage them through Ticket view, where they won't be blocked.
28 Sep 2020 20:32 - 28 Sep 2020 21:27 #3 by GIROUXC
The customize module cannot do a work flow with permissions per profile even if I try to do it with the simplified ticket. I admit that I am disappointed because I was counting on it. May I suggest you add this functionality to manage the work flow including the two criteria: authorization by status and by profile. What seems to me to be a more efficient and complete work flow.
But I am writing to you for another problem that causes module activation. Two fields appear at the top of the posts and remain visible in all the posts even if I want them removed. "Context2" and "Context 3".
The attached file displays the two fields at the top. They are there for all tickets even those that are not customized.
Last edit: 28 Sep 2020 21:27 by GIROUXC.
29 Sep 2020 17:58 #4 by babynus
Strange, as I think it is an already fixed issue.
Which version of ProjeQtOr are you using ?
30 Sep 2020 16:31 #5 by GIROUXC
bug :
I now have version 8.6, I had 8.3. The bug is now that there is an intersection with these fields of the ticket; "operating system", "context", "browser". If we hide one of the three, it is another which is hidden but retaining the title of another. It's a bit long to explain, so give it a try. Finally, if we hide the three, there they are all masked
