ProjeQtOr free project management software - [SOLVED] help me installing projeqtor with postgress pdo - ProjeQtOr
26 Jun 2020 07:06 #1 by redneurocom
hi, i have all extensions enables but im getting do postgress isues
my ph.ini
extension=php_pdo_pgsql.dll
extension=php_pgsql.dll
extension=pgsql.so
extension=pdo_pgsql.so
dev console error in installation page when i choose postgress and send all details
dojo.js?version=V8.5.1.0255:2 _4c0 {message: "Unable to load ../tool/configCheck.php?destination…nType=&xhrPostTimestamp=1593147228479 status: 500", response: {…}, status: 500, responseText: "<div class='messageOK'><i>PHP version is 7.4.7 : O…n = pgsql:host=127.0.0.1;port=3306</i></div><br/>", xhr: XMLHttpRequest, …}message: "Unable to load ../tool/configCheck.php?destinationWidth=560&destinationHeight=65&isIE=&xhrPostDestination=configResultDiv&xhrPostIsResultMessage=false&xhrPostValidationType=&xhrPostTimestamp=1593147228479 status: 500"response: data: "<div class='messageOK'><i>PHP version is 7.4.7 : OK</i></div><br/><div class='messageOK'><i>Module PDO is available : OK</i></div><br/><div class='messageOK'><i>Module PDO for 'PGSQL' is available : OK</i></div><br/><div class='messageOK'><i>Module MBSTRING is available : OK</i></div><br/><div class='messageOK'><i>Class ZipArchive is available : OK</i></div><br/><div class='messageOK'><i>Module DOMDocument is available : OK</i></div><br/><div class='messageOK'><i>GD Library is available and correctly installed : OK</i></div><br/><div class='messageOK'><i>Module IMAP is available : OK</i></div><br/><div class='messageOK'><i>Module OPENSSL is available : OK</i></div><br/><div class='messageOK'><i>Module XML is available : OK</i></div><br/><div class='messageOK'><i>max_input_vars=5000 : OK</i></div><br/><div class='messageOK'><i>max_execution_time=30 : OK</i></div><br/><div class='messageOK'><i>memory_limit=1024M : OK</i></div><br/><div class='messageOK'><i>file_uploads=1 : OK</i></div><br/><div class='messageOK'><i>session.auto_start is disabled : OK</i></div><br/><div class='messageOK'><i>register_globals is disabled : OK</i></div><br/><div class='messageERROR'><i>SQLSTATE[08006] [7] could not connect to server: Permission denied↵ Is the server running on host "127.0.0.1" and accepting↵ TCP/IP connections on port 3306?<br/>dsn = pgsql:host=127.0.0.1;port=3306</i></div><br/>"getHeader: ƒ _338(_339)loaded: 1396options: TMP {method: "POST", handleAs: "text", ioArgs: {…}, data: "param%5BDbType%5D=pgsql&pname%5BDbType%5D=paramDbT…%3D&location=..%2Ffiles%2Fconfig%2Fparameters.php"}status: 500text: "<div class='messageOK'><i>PHP version is 7.4.7 : OK</i></div><br/><div class='messageOK'><i>Module PDO is available : OK</i></div><br/><div class='messageOK'><i>Module PDO for 'PGSQL' is available : OK</i></div><br/><div class='messageOK'><i>Module MBSTRING is available : OK</i></div><br/><div class='messageOK'><i>Class ZipArchive is available : OK</i></div><br/><div class='messageOK'><i>Module DOMDocument is available : OK</i></div><br/><div class='messageOK'><i>GD Library is available and correctly installed : OK</i></div><br/><div class='messageOK'><i>Module IMAP is available : OK</i></div><br/><div class='messageOK'><i>Module OPENSSL is available : OK</i></div><br/><div class='messageOK'><i>Module XML is available : OK</i></div><br/><div class='messageOK'><i>max_input_vars=5000 : OK</i></div><br/><div class='messageOK'><i>max_execution_time=30 : OK</i></div><br/><div class='messageOK'><i>memory_limit=1024M : OK</i></div><br/><div class='messageOK'><i>file_uploads=1 : OK</i></div><br/><div class='messageOK'><i>session.auto_start is disabled : OK</i></div><br/><div class='messageOK'><i>register_globals is disabled : OK</i></div><br/><div class='messageERROR'><i>SQLSTATE[08006] [7] could not connect to server: Permission denied↵ Is the server running on host "127.0.0.1" and accepting↵ TCP/IP connections on port 3306?<br/>dsn = pgsql:host=127.0.0.1;port=3306</i></div><br/>"transferType: "download"url: "../tool/configCheck.php?destinationWidth=560&destinationHeight=65&isIE=&xhrPostDestination=configResultDiv&xhrPostIsResultMessage=false&xhrPostValidationType=&xhrPostTimestamp=1593147228479"xhr: XMLHttpRequest {onreadystatechange: null, readyState: 4, timeout: 0, withCredentials: false, upload: XMLHttpRequestUpload, …}__proto__: ObjectresponseText: "<div class='messageOK'><i>PHP version is 7.4.7 : OK</i></div><br/><div class='messageOK'><i>Module PDO is available : OK</i></div><br/><div class='messageOK'><i>Module PDO for 'PGSQL' is available : OK</i></div><br/><div class='messageOK'><i>Module MBSTRING is available : OK</i></div><br/><div class='messageOK'><i>Class ZipArchive is available : OK</i></div><br/><div class='messageOK'><i>Module DOMDocument is available : OK</i></div><br/><div class='messageOK'><i>GD Library is available and correctly installed : OK</i></div><br/><div class='messageOK'><i>Module IMAP is available : OK</i></div><br/><div class='messageOK'><i>Module OPENSSL is available : OK</i></div><br/><div class='messageOK'><i>Module XML is available : OK</i></div><br/><div class='messageOK'><i>max_input_vars=5000 : OK</i></div><br/><div class='messageOK'><i>max_execution_time=30 : OK</i></div><br/><div class='messageOK'><i>memory_limit=1024M : OK</i></div><br/><div class='messageOK'><i>file_uploads=1 : OK</i></div><br/><div class='messageOK'><i>session.auto_start is disabled : OK</i></div><br/><div class='messageOK'><i>register_globals is disabled : OK</i></div><br/><div class='messageERROR'><i>SQLSTATE[08006] [7] could not connect to server: Permission denied↵ Is the server running on host "127.0.0.1" and accepting↵ TCP/IP connections on port 3306?<br/>dsn = pgsql:host=127.0.0.1;port=3306</i></div><br/>"status: 500xhr: XMLHttpRequest {onreadystatechange: null, readyState: 4, timeout: 0, withCredentials: false, upload: XMLHttpRequestUpload, …}stack: "Error: Unable to load ../tool/configCheck.php?destinationWidth=560&destinationHeight=65&isIE=&xhrPostDestination=configResultDiv&xhrPostIsResultMessage=false&xhrPostValidationType=&xhrPostTimestamp=1593147228479 status: 500↵ at new _4c0 (sispro.redneurocom.com/external/dojo/doj...V8.5.1.0255:2:128459)↵ at _3fc._31e [as handleResponse] (sispro.redneurocom.com/external/dojo/doj...=V8.5.1.0255:2:85907)↵ at XMLHttpRequest._32c (sispro.redneurocom.com/external/dojo/doj...=V8.5.1.0255:2:86343)"__proto__: Error
_3da @ dojo.js?version=V8.5.1.0255:2
(anonymous) @ dojo.js?version=V8.5.1.0255:2
_18b @ dojo.js?version=V8.5.1.0255:2
_189 @ dojo.js?version=V8.5.1.0255:2
reject.errback @ dojo.js?version=V8.5.1.0255:2
_3fd @ dojo.js?version=V8.5.1.0255:2
_3f7 @ dojo.js?version=V8.5.1.0255:2
_415.reject @ dojo.js?version=V8.5.1.0255:2
_403 @ dojo.js?version=V8.5.1.0255:2
_31e @ dojo.js?version=V8.5.1.0255:2
_32c @ dojo.js?version=V8.5.1.0255:2
load (async)
_325 @ dojo.js?version=V8.5.1.0255:2
xhr @ dojo.js?version=V8.5.1.0255:2
dojo.xhr @ dojo.js?version=V8.5.1.0255:2
dojo.rawXhrPost.dojo.xhrPost @ dojo.js?version=V8.5.1.0255:2
loadContent @ projeqtor.js?version=V8.5.1.0255:999
eval @ VM1580:7
_onSubmit @ projeqtorDojo.js:2
__onClick @ projeqtorDojo.js:2
Show 6 more frames
why cannot recognize do even if i installed all required files?
my vps has centos 8 and postgresql 12.1 with PHP 7.4 fresh installation
30 Jun 2020 09:29 #2 by babynus
This is a duplicate post
