ProjeQtOr free project management software - [SOLVED] Create Project/activities/others by importing an excell sheet - ProjeQtOr
17 Apr 2020 19:30 #1 by Cpt_Jabberwock
I would like to know if it is possible to somewhat auto-create elements using an excell sheet with information
Bulk creation, i would say
Example with column letter corresponding to an element on a screen:
A = Name
B = type of project/activity/etc
C = Description
D = etc....
Thank you
18 Apr 2020 19:18 #2 by babynus
You can import any item (projects, activities, tickets,...) in csv format.
In import screen, you'll have help to know expected format.
But easiest is to export list from dedicated screen. For instance export tickets from ticket screen : you'll get the expected format, as all exported files can instantly be imported.
20 Apr 2020 09:40 #3 by Cpt_Jabberwock
Thank you :)
I must have missed it on the 100+ times I looked at the options in Tools.
Everything is OK
Have a good day
