ProjeQtOr free project management software - Error when calculating planning in view Planning (No data to display) - ProjeQtOr
15 Apr 2020 01:26 #1 by msassi
Recently, I installed projeqtor V8.2.4
- I did my best to configurate projeqtor in interafce "global paramters". (Please see screenshot attached below)
- I created a custom workflow, project, some ressources
- I added some activities where ressources are assigned
Then I openned interface "Planning". Unlucky, I have following problems with planning :
- Not all planning are displayed. Planning is displayed only till current day. Only activities that were already filled by ressources into timesheet are displayed. (Please see screenshot attached below)
- 2 off days (Saturday and Synday) don't have grey colour. They are not shaded (Please see screenshot attached below)
- When right click into activity planned in current day, I have error "No data to display. Planning calculation required" (Please see screenshot attached below)
I need to get a complete planning.
Any help please.
Thank you in advance.
17 Apr 2020 09:18 #2 by babynus
Message in pop-op (at right click on bar) is clear : you need to calculate planning (use big gear button on planning screen)
18 Apr 2020 01:34 - 18 Apr 2020 01:36 #3 by msassi
If you mean button that I mentionned in attached screenshot, I answer that it doesn't resolve problem. (Please take look below to screenshot)
I used it since first time, and however planning is calculated I have always same problem.
Last edit: 18 Apr 2020 01:36 by msassi.
18 Apr 2020 19:25 #4 by babynus
When you click on this button, you get the list of projects that will be calculated.
Be sure to select your project and click OK.
Please post new screenshot afterward.
18 Apr 2020 20:04 #5 by msassi
I did it but I have same error :( (Please see below screenshot)
I selected "All project", then I selected only my project and finally I selected all project I have but no way
19 Apr 2020 13:51 #6 by babynus
OK,
So your project or task is not planned.
Several possible reasons :
- you don't have right to calculate planning for this project
- project is administrative (lokk at project type)
- project has "fix planning" (look at value for checkbox)
- task has "fix planning" (look at value for checkbox)
