ProjeQtOr free project management software - Need help for SAML sso with gsuite - ProjeQtOr
12 Apr 2020 07:04 #1 by jiehowe
I plan to switch to authenticating with google sso, but I have no idea where and how to start,
Can anyone pleaser give me some help?
Thank
14 Apr 2020 12:46 #2 by babynus
First, you must know what SAML SSO is.
Read few toturials to understand what IDP and SP are.
Then, when you have a correct working IDP :
- enter configuration of Projeqtor SP in global Parameters (tab authentication)
- when all is done, click on button "Display the Metadata of SP" and copy the xml data you get
- enter the xml definition of Projeqtor SP in your IDP
14 Apr 2020 17:02 - 14 Apr 2020 17:57 #3 by jiehowe
Solved, Thank you very much admin
Last edit: 14 Apr 2020 17:57 by jiehowe.
19 May 2022 14:58 #4 by ckumarac
can you please share details of configuration with google? i configured but got error
403. That’s an error.
Error: app_not_configured_for_user
Service is not configured for this user.
19 May 2022 17:33 #5 by babynus
I'm not sure it may work with Google.
SSO connection in PROJEQTOR uses SAML2 protocole.
I think Google uses Oauth2, not sure SAML2 is available.
But sure for both an interaction in Google is required to define the service provider (SP in SAML)
23 May 2022 16:48 #6 by ckumarac
Google supported SAML2
