ProjeQtOr free project management software - How FTE variation works? - ProjeQtOr
06 Apr 2020 04:21 #1 by rakoun
Bonjour,
I discover a very nice functionnality in Projeqtor, the ability to set FTE for a period.
So I set my ressource's default FTE to 1 and I set a COVID-19 FTE to 0.5 in "FTE variation" from 01/04/2020 to 31/05/2020.
But when I return to my gannt view and ask projeqtor to calculate my project, for a task with a charge of 8 hours it does not change its real spent time to 2 days but lets 1 day.
What is wrong in my configuration?
PS: 8 hours is my default number of working hour in a day
06 Apr 2020 10:38 #2 by babynus
Replied by babynus on topic How FTE variation works?
There's nothing wrong with your configuration, it's about undestanding what variation of capacity is.
It does not change duration of a day, so that a full work day is now half a day.
Moreover it won't impact real work entered.
It is just a way to plan the resource with a different capacity than usual one.
For exemple if you need the resource to work for extra time every day to cover some extra work during a period.
It can also be (for covid period) that the resource will be planned only half days during the period.
But it's only for planning, it won't have any effect on real work entered. It will just point out in timesheet that only 0,5 day is expected (sum for day is green when sum entered is 0,5), but resource is always able to enter more (or less) to reflect what he really worked.
06 Apr 2020 11:42 #3 by rakoun
Replied by rakoun on topic How FTE variation works?
babynus wrote: There's nothing wrong with your configuration, it's about undestanding what variation of capacity is.
Thanks for the answer. So do I need to set my tasks charge to 50%?
06 Apr 2020 15:35 #4 by babynus
If you mean "assignment rate at 50%", NO.
Resource capacity to 0,5 will be enough to limit planning.
13 May 2020 16:07 - 14 May 2020 15:09 #5 by rakoun
Hum...
Perhaps I did not understand.
Below my configuration with standard FTE of 1 and no variation:
And below a task in my planning with this configuration (task duration is 8h):
Now I change my FTE configuration inserting a period of variation with a FTE of 0.5 and keep a standard FTE of 1. (the example task is in the period and begin 15 june)
this is the result on my planning?
I expected that Projeqtor will put the task on two days and not only one day.
What is wrong?
Last edit: 14 May 2020 15:09 by rakoun.
14 May 2020 08:47 #6 by alainforma
Replied by alainforma on topic How FTE variation works?
Please , post on the forum directly to make it easier for our community
