ProjeQtOr free project management software - [SOLVED] Gantt is not displayed - ProjeQtOr
21 Mar 2020 20:24 #1 by pipobru
I use 8.3.5 version and for some users gant on planing screen are not displayed.
Can you help me ?
Bruno.
23 Mar 2020 10:01 #2 by Arkhanje
Replied by Arkhanje on topic Gantt is not displayed
I have no errors on my side.
Are you thinking of moving the splitter to the left?
Your Diagram may simply be hidden.
If not, would you like to post a screenshot of this error and give us more information about your installations?
23 Mar 2020 13:21 #3 by pipobru
Replied by pipobru on topic Gantt is not displayed
Thanks for you answer. I have re create the user, with same rule. Now it is OK.
I close the subject.
The following user(s) said Thank You: Arkhanje
