ProjeQtOr free project management software - [SOLVED] Problem displaying icons in report - ProjeQtOr
19 Feb 2020 11:45 - 19 Feb 2020 11:46 #1 by Rand
I encountered a problem with the display of icons in report.
Some icons are well displayed otherwise others not.
Here are the screenshots
Last edit: 19 Feb 2020 11:46 by Rand.
19 Feb 2020 11:54 #2 by babynus
Which report ?
Please check browser console.
You should have errors reported.
19 Feb 2020 12:02 #3 by Rand
Yeah i got errors reported.
This are the errors displayed :
dojo/parser::parse() error Error: Tried to register widget with id==yearSpinner but that id is already registered
Error parsing in _ContentSetter#null Error: Tried to register widget with id==yearSpinner but that id is already registered
Error undefined running custom onLoad code: This deferred has already been resolved
I've already tried to disable the parseOnLoad but didn't worked.
19 Feb 2020 12:22 #4 by babynus
You have some duplicates in report parameters.
This may come from double install of same version (install, reverse, reinstall)
Remove duplicates in table reportparameter (same name, same idReport)
The following user(s) said Thank You: Rand
19 Feb 2020 13:41 #5 by Rand
You were right !
Thank you a lot for your help :)
