ProjeQtOr free project management software - [SOLVED] How does the "detailSection is build? - ProjeQtOr
10 Feb 2020 17:32 #1 by antoine1003
Hey guys,
I am currently working on a module on projeqtor, which add some fields to some objects. I try to find a documentation online but it appears that no documentation is available for developper (10 year running project and no doc...).
Nevermind, I tried to understand myself the code but the 5900 lines of the objectDetail.php is not really programmer friendly.
I wonder if the field are associated with object's properties, in the database (is there any doc of the database by the way? :whistle: ) or maybe are they generated by dojo?
If I want to add some fields where should declare them, wich type?
Thanks for your help.
A.
11 Feb 2020 09:28 #2 by babynus
Yes, ProjeQtOR is not a development framework. It is a fully operational application. So we focus on User Manual (which is already a big piece of work with more than 500 pages in PDF format) and don't spend much time on technical document.
I agree that if you try and change things in objectDetail.php (which is the core of the screen design) you'll have some problems. You'll also loose compatibility with standard version....
Yes.
No
They are rendered by Dojo
I think the best way is to have a look at our plugins : we propose the screen cusctomizatrion plugin which is dedicated to adding fields (and few other cute things)
13 Feb 2020 16:05 #3 by antoine1003
Okay thanks for the reply :)
