ProjeQtOr free project management software - Project cannot be created, connection lost. - Page 2 - ProjeQtOr
18 May 2020 17:39 #7 by informatique@coopdefrance.coop
Same problem with installation from scratch with MySQL8, Dropdown list dont appear
18 May 2020 18:06 #8 by babynus
Issue is not with MySql8 . I trested with MySql 8.0.16 and all works fine.
What is strange is that you don't get listboxes.
Please show description (DESC) fo table project.
18 May 2020 18:23 #9 by informatique@coopdefrance.coop
in attachement ,the project file description
File Attachment:
File Name: project_table.txt
File Size:2 KB
19 May 2020 11:51 - 19 May 2020 11:52 #10 by babynus
Strange, in your description, formant int also includes the "unsigned" attribute.
It this is result of DESC command, this may explain bad behavior.
Can you try and add 2 lines after line 3691 in file projeqtor/model/persistence/SqlElement.php, this may
      $from [] = 'bigint';
      $to [] = 'int';
      $from [] = 'int unsigned';
      $to [] = 'int';
Please tell us if this fixes the issue.
Last edit: 19 May 2020 11:52 by babynus.
19 May 2020 12:07 #11 by informatique@coopdefrance.coop
i added the 2 lines but it still doesn't work
regards
19 May 2020 18:34 #12 by babynus
Can you please help us debug : add 1 new line in projeqtor/model/persistence/SqlElement.php after line 3696, like this :
      $type = str_ireplace ( $from, $to, $type );
      $formatList [strtolower ( $fieldName )] = $type;
      debugLog("$class | $fieldName=>$type");
Then change file parameters.php (default location is in projeqtor/files/config) to set
$logLevel=3;
Access project and post here log projeqtor file.
Time to create page: 0.062 seconds
