ProjeQtOr free project management software - [SOLVED] Update 7.0.9 to 8.2.4, problems with feature not available - ProjeQtOr
06 Feb 2020 13:20 #1 by Rand
I faced issues when i updated projeqtor 7.0.9 to 8.2.4.
When i click for example on "Absence" it says:
"This feature is not available in this version of ProjeQtOr, Sorry... "
I already checked similar post and cleaned the cach of the browser but it didn't worked.
Any suggestions to fix this problem ?
07 Feb 2020 15:34 #2 by babynus
I think is is only a javascript cache issue.
Just clear your browser cache.
10 Feb 2020 10:39 #3 by Rand
Thank for the quick response but like i said it didn't worked even if I clean my browser cache.
10 Feb 2020 11:11 #4 by Gautier
Could you post your log file please ?
10 Feb 2020 13:16 #5 by Rand
Yeah sure, here is the log file.
File Attachment:
File Name: projeqtor_...0210.log
File Size:805 KB
10 Feb 2020 14:24 #6 by babynus
There is no issue that could explain the behavior you face.
Please check code of file projeqtor/view/js/projeqtorDialog.js, line 7062 should be
  } else if (item == 'Absence') {
	    loadContent("absenceMain.php", "centerDiv");
If it's not the case, try and reinstall.
The following user(s) said Thank You: Rand
