ProjeQtOr free project management software - Extract project from MariaDB in order to inject into MySql to Projeqtor - ProjeQtOr
14 Jan 2020 14:01 #1 by M.
Hi all,
Is that possible to extract a project from projeqtor (MaridaDB) in order to puch it into projeqtor with the Mysql format.
We just try to adopt this solution which seems perfect for our configuration, but we need to know firstly if that case is possible in order to not publish again all the project lines.
Thanks for your help.
Rgds,
Matéo
15 Jan 2020 14:11 #2 by babynus
No.
There are many dependencies that won't be taken.
You can possibly export into CSV format and then reimport, but you'll get only Project, not its content.
15 Jan 2020 14:20 #3 by M.
Thanks for your return.
Ok for the project, but may i use the same process with activities ?
My main goal is to merge from Mariadb (which is my QA) to Mysql (which may be the prod.).
Thanks a lot for your disponibility.
Rgds
Matéo
15 Jan 2020 14:25 #4 by babynus
Yes, you can do the same for activities and most ohter objects (tickets, resources, ...)
But just to move from MariaDB to MySql (or the other way round) it's more easy to export full dump of db and reimport.
(MariaDb and MySql are the same)
