ProjeQtOr free project management software - [SOLVED] How to get specific URL for a Project? - Page 2 - ProjeQtOr
18 Dec 2019 09:06 - 18 Dec 2019 09:07 #7 by coffe1nk
Hi lean-sigma,
I tried your solution,
* select project
* click print button
* popup gantt chart is shown
* right click -> open frame in new tab
but, after new tab, it didn't show anything..
URL: http://xxxx:8080/projector/view/print.php?print=true&page=planningPrint.php&context=planning&objectClass=Project&objectId=1&orientation=L&outMode=html&startDate=2019-12-18&endDate=2019-12-18&format=day
Anyway, how to make this request as a feature? request for direct URL to gantt chart per project.
thanks and Regards,
Last edit: 18 Dec 2019 09:07 by coffe1nk.
18 Dec 2019 18:46 #8 by lean-sigma
It looks like you copied the URL from the planning page instead of from the Gantt report page :
You should go to "follow-up" then "Report" then "planning" then "Gantt planning". Select your projet and open the frame in a new tab.
In this URL, you can replace the idProjet to show up the projet you want to access to.
Best regards,
18 Dec 2019 23:47 - 18 Dec 2019 23:47 #9 by coffe1nk
Oh, got it...
Thank you so much lean-sigma
That's enough for me...
again, thank you and best regards.
Last edit: 18 Dec 2019 23:47 by coffe1nk.
