ProjeQtOr free project management software - [SOLVED] Empty Project Slots since upgrade to v8.2.4 - Page 2 - ProjeQtOr
15 Dec 2019 18:59 #7 by babynus
I tried to do the delete thing that you described and I had a problem at the the first step. I am in the Administrator Account, click on projects and applied the filter for "name" as empty. The results came back as 0 projects.
It seems name is not null but empty string (or just spaces)
You can possibly locate them on list of project and select them in multiple-update mode to delete them
I discovered that I can I cannot delete each project individually either. The delete button is greyed out even when I click on one of these empty projects
Strange, it seem you have no right to delete them...
Did you connect as admin ?
16 Dec 2019 01:49 #8 by iconic
I am connected as ADMIN Account but the the delete button is greyed out. Is there something I am doing wrong, or a feature I have to activate for Administrator to delete them one at a time.
16 Dec 2019 01:51 #9 by iconic
Using the Administrator Account I pressed on the multiple button (the button with the 2 save discs) displaying.
I selected these emply projects and when I clicked to delete them I receive this error.
#223 :
Invalid controls.
you don't have rights to delete this item
#197 :
Invalid controls.
#196 :
Invalid controls.
#195 :
Invalid controls.
#194 :
Invalid controls.
#193 :
Invalid controls.
#192 :
Invalid controls.
#191 :
Invalid controls.
17 Dec 2019 17:12 #10 by babynus
Can you chack access rights for Project ?.
On Acces Rights > Access to Data (project dependant), check that Admin profile hase mod e"Manager+" on Project.
18 Dec 2019 01:23 #11 by iconic
Using my administrator access login details, I logged in and checked and under Access to data (project dependent) Administrator has Manager+ showing. In fact in almost everything it has Manager+ selected.
21 Dec 2019 17:00 #12 by babynus
It's very strange, I never faced such issue.
I made several migrations to V8.3, on several systems (Linux / Windows, MySql / Postgres) without reproducing such isse.
I'm afraid you'll have to delete manualy (I hate this, but it seems to be the only solution).
Here is the query to do this :
delete from planningelement where refType='Project' and refId in (select id from project where idProjectType is null and creationDate is null);
delete from project where idProjectType is null and creationDate is null;
Please be sure to backup your database before executing the query in case of too large deletion.
