ProjeQtOr free project management software - Quotations and planning - ProjeQtOr
15 Nov 2019 06:19 #1 by burgerzs
If someone has to give an estimation to a Client Quotation, then most of the time this process takes several hours/days of work, so this work needs to be planned.
It seems to me that Quotations are not in the plan, then a new Activity has to be created for that? What is the best way to do this?
Zsolt
15 Nov 2019 08:33 #2 by babynus
Replied by babynus on topic Quotations and planning
Quotation is the sheet when you quote things.
If you need to record time spent, you have to create an Activity.
Then you can link activity and quotation or select origin of activity as quotation (or reverse)
The following user(s) said Thank You: burgerzs
