ProjeQtOr free project management software - Problem opening the Follow-Up>Planning Tab - ProjeQtOr
13 Nov 2019 09:39 #1 by #Chris
We have a Problem with the Follow-Up>Planning Tab.
Basically, it does not open on most of the clients. It does however open on my machine and the server itself.
It does take about 20 seconds to load but thats probably due to the huge ammount of projects we have (260).
I have increased the php memory limit to around 2GB and set the timeout for scripts to 5 Minutes.
The Server is a windows server 2016 VM, MySQL, 4CPU, 6GB RAM, 10G Ethernet, SSD FC Storage.
My Machine and the server where the first 2 to open the page. No one else can open it. We have tried different PCs, Browsers (IE, Edge, Chrome, Firefox) and none work.
I have restartet the server multiple times.
If you need any logfiles or config files I'm happy to provide them.
BR,
Alex
13 Nov 2019 15:27 #2 by babynus
Trying to display very big Gantt may block the browser.
260 project x number of activities per project may lead to very numerous lines to display.
This may be too much for most browsers.
Try and select a project in the project selector to limit display, planning should display easily.
