ProjeQtOr free project management software - Unable to change project values - ProjeQtOr
28 Oct 2019 11:47 - 28 Oct 2019 11:48 #1 by pakkes
I'm facing an issue while trying to change any project value. I guess the reason is noticed by the message "Need replan" as you can see on the attached picture.
May you please kindly suggest me how to solve this?
Many thanks in advance.
Last edit: 28 Oct 2019 11:48 by pakkes.
29 Oct 2019 11:35 #2 by babynus
You just cannot change fields that are designed as "readonly" ... because they are calculated.
You must change the values of data that will calculate these fields.
The "need replan" just points out that you changed some data (assigned work, left work, ...) that may have impact on the planning of the project, so you need to recalculate the planning.
29 Oct 2019 15:01 #3 by pakkes
Many thanks for your quick reply.
However I'm not sure I have understood: are you saying I cannot change the name of a Project?
29 Oct 2019 19:07 #4 by babynus
No, you can if you have rights.
If you are admin, you can update any project.
If you are project leader, you can update projects you are allocated to.
Your project has no allocated resource, so possibly issue is there.
13 Nov 2019 09:48 #5 by pakkes
Hi.
In first I apologize for my delay in replying to your answer.
This supposed issue (and other issues I got until a few days ago, all of them apparently related to the 'saving record' action) was simply caused by an antivirus mounted on top of my Apache installation. No more problem after I tuned the Bitdefender antivirus to allow Apache trafic.
