ProjeQtOr free project management software - How to stop staff creating Project Using Permissions? - Page 2 - ProjeQtOr
26 Sep 2019 11:11 #7 by iconic
I have tried to go to allocation to Project in the project where he is a resource and when I click profile, it does not show the profile I created for him. It only show the 7 default ones.
26 Sep 2019 11:13 #8 by iconic
And under their Resource Account under profile: it shows the one I created, but he Allocations to Project shows the default profile. When I try to edit it on the drop down box in Edit, it only displays the 7 default profiles.
26 Sep 2019 11:37 #9 by alainforma
you have just to disconnect and reconnect. Changes will be taken into account.
27 Sep 2019 02:21 #10 by iconic
I disconnected from my admin account and reconnected. I went to Resources, selected the user, clicked on the Edit button and does not show the profile I created. Still only shows the default ones.
27 Sep 2019 04:05 #11 by iconic
I thought I might help if I attached the images for you to see.
Image 1 = shows the resource and the profile correctly although it has the name as [ .... ]
Image 2 - shows the allocation window where it does not show the profile I created.
27 Sep 2019 10:00 #12 by babynus
Your new profile has no sort sorder and is so "on top".
So only resources with this profile will be able to allocated a resource with this profile.
The rule is that resource cannot allocate resource with a profile "above his own".
This is done to avoid that a project leader gives admin rights to someone ;)
So take care to order of profiles, it is important.
