ProjeQtOr free project management software - [SOLVED] save planning reference (on 8.2.1) - ProjeQtOr
29 Aug 2019 14:04 #1 by pipobru
Hello, on last version (8.1.5) when i would save planning reference i have this sql error:
2019-08-29 13:41:55.798 ***** ERROR ***** [V8.1.5] Exception-[42703] SQLSTATE[42703]: Undefined column: 7 ERROR: column "surbooked" does not exist
LINE 2: SELECT surbooked, surbookedWork, idResource, idProject, refT...
HINT: There is a column named "surbooked" in table "plannedworkbaseline", but it cannot be referenced from this part of the query.
2019-08-29 13:41:55.798 ***** ERROR ***** [V8.1.5] For query : INSERT INTO plannedworkbaseline (surbooked, surbookedWork, idResource, idProject, refType, refId, idAssignment, work, workDate, day, week, month, year, dailyCost, cost, idBaseline, isRealWork)
SELECT surbooked, surbookedWork, idResource, idProject, refType, refId, idAssignment, work, workDate, day, week, month, year, dailyCost, cost, 9, 1 FROM work
where idProject in (41, 55)
2019-08-29 13:41:55.798 ***** ERROR ***** [V8.1.5] Strack trace :
2019-08-29 13:41:55.798 ***** ERROR ***** [V8.1.5] #0 Sql->query called at [/var/www/html/model/persistence/SqlDirectElement.php:83]
2019-08-29 13:41:55.798 ***** ERROR ***** [V8.1.5] #1 SqlDirectElement->execute called at [/var/www/html/model/Baseline.php:122]
2019-08-29 13:41:55.798 ***** ERROR ***** [V8.1.5] #2 Baseline->copyItem called at [/var/www/html/model/Baseline.php:77]
2019-08-29 13:41:55.798 ***** ERROR ***** [V8.1.5] #3 Baseline->saveWithPlanning called at [/var/www/html/tool/savePlanningBaseline.php:64]
2019-08-29 13:44:24.046 ***** ERROR ***** [V8.1.5] Exception-[42703] SQLSTATE[42703]: Undefined column: 7 ERROR: column "surbooked" does not exist
My databe is postgresql
VEry thanks for your answer
04 Sep 2019 18:27 #2 by babynus
Replied by babynus on topic save planning reference
Issue confirmed...
..and fixed.
Fix is to replace in Baline.php lines 116+ from
    if ($itemFrom=='PlannedWork') { // Also include existing real work
      $objFrom=new Work();
      $tableFrom=$objFrom->getDatabaseTableName();
      $colListWork=str_replace(array('surbookedWork','surbooked'), array('0','0'), $colList);
      $query="INSERT INTO $tableTo ($colList idBaseline, isRealWork)\n"
      ."SELECT $colListWork $idBaseline, 1 FROM $tableFrom \n"
      ." where idProject in ".transformListIntoInClause($proj->getRecursiveSubProjectsFlatList(true, true));
      $res=SqlDirectElement::execute($query);
to
Fix will be included in patch V8.1.6
24 Sep 2019 11:15 #3 by pipobru
Hello on the last version, when i would save planning reference i have this trace:
2019-09-24 11:10:51.033 ***** ERROR ***** [V8.2.1] Exception-[42703] SQLSTATE[42703]: Undefined column: 7 ERROR: column "minimumthreshold" of relation "planningelementbaseline" does not exist
LINE 1: ...lementary, idle, done, cancelled, idPlanningMode, minimumThr...
2019-09-24 11:10:51.033 ***** ERROR ***** [V8.2.1] For query : INSERT INTO planningelementbaseline (idProject, refType, refId, refName, initialStartDate, validatedStartDate, validatedStartFraction, plannedStartDate, plannedStartFraction, realStartDate, initialEndDate, validatedEndDate, validatedEndFraction, plannedEndDate, plannedEndFraction, realEndDate, initialDuration, validatedDuration, plannedDuration, realDuration, initialWork, validatedWork, assignedWork, plannedWork, leftWork, realWork, progress, validatedCost, assignedCost, plannedCost, leftCost, realCost, expectedProgress, wbs, wbsSortable, topId, topRefType, topRefId, priority, elementary, idle, done, cancelled, idPlanningMode, minimumThreshold, indivisibility, idBill, validatedCalculated, validatedExpenseCalculated, latestStartDate, latestEndDate, isOnCriticalPath, notPlannedWork, isManualProgress, surbooked, idBaseline)
SELECT idProject, refType, refId, refName, initialStartDate, validatedStartDate, validatedStartFraction, plannedStartDate, plannedStartFraction, realStartDate, initialEndDate, validatedEndDate, validatedEndFraction, plannedEndDate, plannedEndFraction, realEndDate, initialDuration, validatedDuration, plannedDuration, realDuration, initialWork, validatedWork, assignedWork, plannedWork, leftWork, realWork, progress, validatedCost, assignedCost, plannedCost, leftCost, realCost, expectedProgress, wbs, wbsSortable, topId, topRefType, topRefId, priority, elementary, idle, done, cancelled, idPlanningMode, minimumThreshold, indivisibility, idBill, validatedCalculated, validatedExpenseCalculated, latestStartDate, latestEndDate, isOnCriticalPath, notPlannedWork, isManualProgress, surbooked, 11 FROM planningelement as PlanningElement
where idProject in (56, 59, 60)
2019-09-24 11:10:51.033 ***** ERROR ***** [V8.2.1] Strack trace :
2019-09-24 11:10:51.033 ***** ERROR ***** [V8.2.1] #0 Sql->query called at [/var/www/html/model/persistence/SqlDirectElement.php:83]
2019-09-24 11:10:51.033 ***** ERROR ***** [V8.2.1] #1 SqlDirectElement->execute called at [/var/www/html/model/Baseline.php:115]
2019-09-24 11:10:51.033 ***** ERROR ***** [V8.2.1] #2 Baseline->copyItem called at [/var/www/html/model/Baseline.php:76]
2019-09-24 11:10:51.033 ***** ERROR ***** [V8.2.1] #3 Baseline->saveWithPlanning called at [/var/www/html/tool/savePlanningBaseline.php:64]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] Exception-[25P02] SQLSTATE[25P02]: In failed sql transaction: 7 ERROR: current transaction is aborted, commands ignored until end of transaction block
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] For query : select * from project where id=56
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] Strack trace :
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #0 Sql->query called at [/var/www/html/model/persistence/SqlElement.php:2939]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #1 SqlElement->getSqlElement called at [/var/www/html/model/persistence/SqlElement.php:672]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #2 SqlElement->__construct called at [/var/www/html/model/ProjectMain.php:188]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #3 ProjectMain->__construct called at [/var/www/html/model/Project.php:40]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #4 Project->__construct called at [/var/www/html/model/Baseline.php:111]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #5 Baseline->copyItem called at [/var/www/html/model/Baseline.php:77]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #6 Baseline->saveWithPlanning called at [/var/www/html/tool/savePlanningBaseline.php:64]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] For query : select * from project where project.idProject is null and project.idle=0
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #0 Sql->query called at [/var/www/html/model/persistence/SqlElement.php:2480]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/html/model/ProjectMain.php:502]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #2 ProjectMain->getRecursiveSubProjects called at [/var/www/html/model/ProjectMain.php:530]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #3 ProjectMain->getRecursiveSubProjectsFlatList called at [/var/www/html/model/Baseline.php:114]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #4 Baseline->copyItem called at [/var/www/html/model/Baseline.php:77]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #5 Baseline->saveWithPlanning called at [/var/www/html/tool/savePlanningBaseline.php:64]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] Exception-[42601] SQLSTATE[42601]: Syntax error: 7 ERROR: syntax error at or near ")"
LINE 3: where idProject in ()
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] For query : INSERT INTO plannedworkbaseline (surbooked, surbookedWork, idResource, idProject, refType, refId, idAssignment, work, workDate, day, week, month, year, dailyCost, cost, idBaseline)
SELECT surbooked, surbookedWork, idResource, idProject, refType, refId, idAssignment, work, workDate, day, week, month, year, dailyCost, cost, 11 FROM plannedwork as PlannedWork
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #0 Sql->query called at [/var/www/html/model/persistence/SqlDirectElement.php:83]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #1 SqlDirectElement->execute called at [/var/www/html/model/Baseline.php:115]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #2 Baseline->copyItem called at [/var/www/html/model/Baseline.php:77]
2019-09-24 11:10:51.034 ***** ERROR ***** [V8.2.1] #3 Baseline->saveWithPlanning called at [/var/www/html/tool/savePlanningBaseline.php:64]
2019-09-24 11:10:51.035 ***** ERROR ***** [V8.2.1] For query : select * from project where project.idProject is null and project.idle=0
2019-09-24 11:10:51.035 ***** ERROR ***** [V8.2.1] Strack trace :
2019-09-24 11:10:51.035 ***** ERROR ***** [V8.2.1] #0 Sql->query called at [/var/www/html/model/persistence/SqlElement.php:2480]
2019-09-24 11:10:51.035 ***** ERROR ***** [V8.2.1] #1 SqlElement->getSqlElementsFromCriteria called at [/var/www/html/model/ProjectMain.php:502]
2019-09-24 11:10:51.035 ***** ERROR ***** [V8.2.1] #2 ProjectMain->getRecursiveSubProjects called at [/var/www/html/model/ProjectMain.php:530]
2019-09-24 11:10:51.035 ***** ERROR ***** [V8.2.1] #3 ProjectMain->getRecursiveSubProjectsFlatList called at [/var/www/html/model/Baseline.php:122]
2019-09-24 11:10:51.035 ***** ERROR ***** [V8.2.1] #4 Baseline->copyItem called at [/var/www/html/model/Baseline.php:77]
2019-09-24 11:10:51.035 ***** ERROR ***** [V8.2.1] #5 Baseline->saveWithPlanning called at [/var/www/html/tool/savePlanningBaseline.php:64]
2019-09-24 11:10:51.035 ***** ERROR ***** [V8.2.1] Exception-[42601] SQLSTATE[42601]: Syntax error: 7 ERROR: syntax error at or near ")"
Thanks for your help !
26 Sep 2019 12:02 #4 by babynus
Issue recorded as Ticket #4224
