ProjeQtOr free project management software - Can't manage to delete a project - ProjeQtOr
19 Aug 2019 12:25 #1 by lsigroup
I'm currently having an issue while trying to delete a project.
I moved all the tickets and activitys to another project and there's no remaining things (tickets, activitys ...), but somehow it keeps telling me that I can't delete it because there's a work allocated to this project (see the screenshot)
Thank you in advance,
19 Aug 2019 14:32 #2 by babynus
Strange.
Possibly some work line is referencing the project.
Try and run consistency check / fix (on admin screen)
19 Aug 2019 15:13 #3 by lsigroup
Thank you for the reply,
I tried the Admin consistency repair tool,
It detected some errors and claimed that it corrected them.
But the errors concerning work keep coming back everytime i use the error scan and continue to say it's corrected.
(Screenshot attached)
20 Aug 2019 10:06 #4 by babynus
Maybe you can try and update one activity of the project.
Add some work, remove it.
In some case, this fixes those consolidation issues.
20 Aug 2019 12:06 - 20 Aug 2019 12:09 #5 by lsigroup
So, I tried to update an activity of the project, didn't change the problem.
I'm not sure that the consistency errors are related to this problem.
In fact, I am working on a test environment, so I restored my db from a backup I did just before I moved the demands and activitys (in order to delete the projects).
I used the check error admin tool, errors were there before and aren't resolving neither.
I am currently not totally getting the meaning of "work" in my error message, like, what can it be if I moved all the demands, activitys, flags ect from the project ?
EDIT : Or maybe you could try to explain me wich reference it represents in the db ? Idk
Last edit: 20 Aug 2019 12:09 by lsigroup.
21 Aug 2019 11:22 #6 by babynus
How did you do this.
Please explain way to do this so that we can try and reproduce.
Better : could you please try and reproduce use case on Demo ?
