ProjeQtOr free project management software - SAML 2.0 installation for 8.10 - ProjeQtOr
15 Jul 2019 15:15 #1 by kishorevenki
I am novice in Linux and I am struggling to install and configure SSO so that 8.10 works.
Please advise.
Thanks & regards,
Kishore
15 Jul 2019 15:31 #2 by babynus
You don't have to deal with linux to configure SSO : just go to Global Parameter page en enter your SSO (IDP) information.
Of course you also must add your SP to your IDP (get metadata to ease this step)
NB : if you need help to install an IDP, it is out of scope of this forum, search the web...
NB : V8.1.0 also works fine without SSO ;)
16 Jul 2019 03:38 #3 by kishorevenki
The logging screen itself is not coming so as to enter the global parameters. Below is the error log from //apache2/error.log
PHP Deprecated: Directive 'track_errors' is deprecated in Unknown on line 0
[Mon Jul 15 00:05:47.563510 2019] [mpm_prefork:notice] [pid 5447] AH00163: Apache/2.4.29 (Ubuntu) OpenSSL/1.1.1 configured -- resuming normal operations
[Mon Jul 15 00:05:47.563690 2019] [core:notice] [pid 5447] AH00094: Command line: '/usr/sbin/apache2'
[Mon Jul 15 10:45:33.875831 2019] [php7:notice] [pid 6684] [client 192.168.1.129:62855] PHP Fatal error: Uncaught Error: Class 'SSO' not found in /var/www/html/projeqtor/view/index.php:56\nStack trace:\n#0 {main}\n thrown in /var/www/html/projeqtor/view/index.php on line 56, referer: http://192.168.1.124/projeqtor/
[Tue Jul 16 00:08:44.498889 2019] [mpm_prefork:notice] [pid 5447] AH00171: Graceful restart requested, doing restart
Kishore
16 Jul 2019 14:27 #4 by babynus
Issue confirmed.
Patch will soon be proposed.
As a workaroud, you can directly go to url http://yourserver/projeqtor/view/main.php
(replace yourserver with your server address)
16 Jul 2019 14:35 #5 by babynus
Patch attached.
V8.1.2 will soon be deployed.
16 Jul 2019 15:39 #6 by kishorevenki
Hi Admin,
The issue is not with the server IP Address or Server domain name. But in the main.php SSO is referred even without it is set.
So I am not able to move further unless and otherwise SSO is bypassed.
Please suggest the solution.
Kishore
