ProjeQtOr free project management software - [SOLVED] planification calculation question - ProjeQtOr
10 Jul 2019 16:13 - 10 Jul 2019 20:41 #1 by pipobru
Hello, I would help the project with my contribution (tests) Very thanks for your job, for me the better tools for manage projets !
My context:
A pool with ghost ressources
tasks on project without dependency or other contraints
My questions:
why in summary of availabilities repport i have number of days planned and not number of days remaining planable (number of ETP * number of working day-number of days planned),
I understand your previous answer on this subject, but i propose to add this information perarps with a different color ?
Why for each days the full pool capacity are not planed ? (all task have no contraint (start date, dependance, ...)
For explain my test see screens shoots in attachement.
Last edit: 10 Jul 2019 20:41 by pipobru.
13 Jul 2019 18:59 #2 by babynus
Because Availability of resources is already counted, so work planned on Pool will subtract availability of resources.
Could be an improvement.
I guess the Pool icon on resource name is already a good hint.
Because when you assign a pool, you specify the FTE you'll take in the pool, and default value is 1.
If you set ETP to capacity of the pool, it will be completely booked
The following user(s) said Thank You: pipobru
15 Jul 2019 10:21 #3 by pipobru
Ok thanks for your answer, but i not anderstand:
If i have a pool with 5 ETP at time T, for me i can planed one task with 5 ETP (When i affect my pool i change the default value from 1 to 5), OR i can planed 5 task with 1 ETP (Default affectation value).
my anderstand's is wrong ?
15 Jul 2019 11:34 #4 by babynus
You're right.
And if you do it this way, your poll should be fully booked.
15 Jul 2019 16:10 #5 by pipobru
Ok but if leave 1 ETP by default, the system don't book the full capacity. in my sample the capacity of my pool is 5 ETP but the fonction of planning calculation reserv only 3,5 or 2,5 ETP. he don't plane all tasks in same time (5 maximum)
18 Jul 2019 10:00 #6 by pipobru
Hello, i have same prolem with 8.1.2 version.
