ProjeQtOr free project management software - [SOLVED] Error on disabling REGULATED ABSENCES MODULE - ProjeQtOr
17 Jun 2019 21:21 #1 by mcanuto
We've been exploring and making tests over this new module and at some point we wanted to begin again, so knowing that by disabling the module, it cleans everything attached to it, I thought I could do that to clean up our tests and begin again.
The issue is that when I abled it again, I got twice the status "submit", "accepted" and "rejeted". I didn't see it at once so I kept doing some tests and when I realised it, I said to myself : "Ok, I'm gonna disable the module, delete the status if they're still there (which happened) and then reable it".
But now, I have no more those three status, and when I look at the log file, I realised my problem:
The disabling fonctionality keeps aborting with the following error :
2019-06-17 20:40:22.262 ***** ERROR ***** [V8.0.4] Exception-[42S02] SQLSTATE[42S02]: Base table or view not found: 1146 Table 'projeqtor.Resource' doesn't exist
2019-06-17 20:40:22.262 ***** ERROR ***** [V8.0.4]    For query : UPDATE Resource SET isEmployee=0 WHERE isEmployee=1
2019-06-17 20:40:22.262 ***** ERROR ***** [V8.0.4]    Strack trace :
2019-06-17 20:40:22.262 ***** ERROR ***** [V8.0.4]    #0 Sql->query called at [/var/www/html/projeqtor/tool/projeqtor-hr.php:451]
2019-06-17 20:40:22.263 ***** ERROR ***** [V8.0.4]    #1 initPurgeLeaveSystemElements called at [/var/www/html/projeqtor/model/Module.php:79]
2019-06-17 20:40:22.263 ***** ERROR ***** [V8.0.4]    #2 Module->save called at [/var/www/html/projeqtor/tool/saveModuleStatus.php:40]
2019-06-17 20:40:22.263 ===== TRACE ===== InitLeaveSystemElement - ERROR on QUERY = UPDATE Resource SET isEmployee=0 WHERE isEmployee=1
2019-06-17 20:40:22.263 ===== TRACE ===== 0 Raison fin de contrat de travail(s) supprimé(s)<input type="hidden" id="lastSaveId" value="" /><input type="hidden" id="lastOperation" value="delete" /><input type="hidden" id="lastOperationStatus" value="OK" /><input type="hidden" id="noDataMessage" value="<br/><i>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;Aucun élément Raison fin de contrat de travail sélectionné.</i>" />
2019-06-17 20:40:22.263 ===== TRACE ===== Change LeaveSystemActiv to NO :ERROR
2019-06-17 20:40:22.263 ===== TRACE ===== 0 Raison fin de contrat de travail(s) supprimé(s)<input type="hidden" id="lastSaveId" value="" /><input type="hidden" id="lastOperation" value="delete" /><br/>LEAVE SYSTEM ERASING ABORTED. Error on resource's update<input type="hidden" id="lastSaveId" value="" /><input type="hidden" id="lastOperation" value="Resource's update" /><input type="hidden" id="lastOperationStatus" value="ERROR" />
I work on a CentOs Server with a mariaDB Database.
Can you help me fix this, please?
Thank you
MCanuto
21 Jun 2019 15:48 #2 by babynus
Issue recorded as Ticket #4081
28 Jun 2019 10:56 #3 by mcanuto
is this Ticket #4081 fixed by the version 8.0.6?
I've installed the latest stable version, but I still have de same trouble.
What can I do, please?
thank you for your help.
MCanuto
28 Jun 2019 16:13 #4 by Gautier
did you clean your browser cache ?
29 Jun 2019 13:08 - 29 Jun 2019 13:08 #5 by babynus
Yes issue you reported
is fixed on V8.0.6
If you still have issue, please report error loggued in log file
Last edit: 29 Jun 2019 13:08 by babynus.
Time to create page: 0.081 seconds
