ProjeQtOr free project management software - How to check for concurrent activities about a resource - Page 2 - ProjeQtOr
11 Jun 2019 11:32 #7 by al_rodin
here it is. Plan is validated and recalculated. Still red
Thanks a lot for your time.
Attachment not found
11 Jun 2019 11:41 #8 by alainforma
hi
the red bar inside indicates only that this activity is on the critical path. That 's it.
Check or uncheck the box to show it.
regards
The following user(s) said Thank You: al_rodin
11 Jun 2019 11:50 - 11 Jun 2019 11:51 #9 by al_rodin
I know it. This is not the topic. The topic is that I'm not able to make the "Create some planning" today's menu turn into green (the START GUIDE page, I mean).
Please notice that this is not the only project. There are two more, still created but not operative (no resources, no nothing). Maybe should they be ALL operative to get it green?
Did not get any mention in the manual about this.
Thanks again for your precious help and time! This is a topic that I would solve asap because I find that Projeqtor could give a big hand in my case, so I want to propose it to my Company.
Last edit: 11 Jun 2019 11:51 by al_rodin.
11 Jun 2019 12:01 #10 by babynus
Can you please check that you have some lines in table plannedwork ?
11 Jun 2019 12:08 #11 by al_rodin
The db is on a remote server. I don't have access to the tables right now, but I made a copy last Sunday. I will try immediately to build up a local server with it.
11 Jun 2019 12:12 #12 by al_rodin
checked. It's empty! I can presume that it's empty also on the remote database
Time to create page: 0.066 seconds
