ProjeQtOr free project management software - MODULE OF MANAGEMENT OF REGULATED ABSENCES - Page 3 - ProjeQtOr
13 Apr 2019 22:38 #13 by babynus
I now fixed te issue about $theWorkFlowId.
I generated a default (simple) workflow that should work fine for leave system.
I also fixed some issues on StatusMain.php about incorrect SQL queries.
15 Apr 2019 14:40 #14 by tabary
First of all, thank you for taking this contribution into account.
For $ theWorkFlowId, you've been faster than me. I did the same thing as you.
As for the display of the calendar, I saw that you had found the solution.
I made a change in view \ js \ projeqtorHR.js on the leaveCalendarDisplay () function to see only the 'Previous' and 'Next' buttons.
See in the patch attached : view-js-projeqtorHR.
By cons, I can not internationalize the calendar. The Calendar widget is based on the locale of the browser even if I change the locale value in dojoConfig or the lang property of the Calendar widget.
By the way, I fixed a bug in tool \ getLeaves.php (see in the patch attached : Tool-getLeaves).
For the generation of the file EXCEL I had also tried with PhpSpreadsheet and had also had the same result as you.
I am looking more finely to find the solution.
Finally, in the version 8.0.0 revision '4729', I noticed that the global parameter allowing to choose the administrator of the module is no longer visible in the global parameters (it worked in the revision of last week).
Hoping to have helped you.
19 Apr 2019 14:54 #15 by babynus
Good idea, buttons were no need.
Patch integrated.
Not an issue...
I don't understand your patch
if (count($resStatus)<0) {
 usort($resStatus, function($a, $b)
         return strcmp($a->sortOrder, $b->sortOrder);
You sort a table only if it is empty ?
Not an issue, we continue with PHP-Excel, but will have to think to replace with phpSpreadsheet (PHPExcel ios not maintained any more)
This is fixed.
It was wrong management of modules.
