ProjeQtOr free project management software - Ability to have multiple view for project, activity, tickets,... - ProjeQtOr
26 Jun 2018 09:49 #1 by dnaton
A suggestion for a future version of ProjeqTor : possibility to have more than one view, :-)
There is a lot of colums but we can't display all what we sometimes need.
Ok, it's easy to modify the view but it takes times :-(
in the project view for example
  • a view for the administrative information,
  • a view for works and cost
  • Views fonction of the type of project
these views could be stored and shared, like filters for example : share theses views could be fine to propose the same look and feel in a Project Team
And why not do the same for all the views in ProjeQtor (tickets, activity, actions,...)
Do you mean it would be interesting ?
Damien
26 Jun 2018 14:25 #2 by babynus
First, view that will fit your need won't fit mine or needs of any other project leader.
So we may not proviede "fixed" view, and should have customisable ones.
It is exactly what our "screen customization" plugin does.
With the plugin, you can for instance define visibility of fields depending on type or depending on status.
We won't provide equivalent in standard as it could kill our business model ;)
18 Apr 2019 10:59 - 18 Apr 2019 11:00 #3 by dnaton
Hello Babynus,
I restart this topic posted a few month ago :-).
I've not explained correctly what I suggest : I have already the plugin "Screen Customization" but use it to modify a few screen (I'm ok with you, fields that will fit my need won't fit yours or needs of any other project leader.
In fact, what I meant is not for screen customisation but the global view of projects, tickets, activity, meeting,....
In theses view, we can choose the columns to display
What I propose as ehancement is the possibility to "define" and "store" different views models (like what you propose with the filters).
With this possibility, we can adapt the view on different "job view", like Project Manager (vith colum to view quickly workload, date,...), or administrative people (with columns like date, cost, expenses,....
Damien
Last edit: 18 Apr 2019 11:00 by dnaton.
19 Apr 2019 15:10 #4 by babynus
Do you mean saving the disposition of columns in the list ?
22 Apr 2019 11:54 #5 by dnaton
yes: define the view with the columns we want, save the configuration by give it a name, and have a menu or icon (like the "sorting" icon) to view the list of different view stored.
With this, we can have views adapted on different "instant" on a project life : some times, I need to see a view with date information, some times I need instead more informations about costs, workload or financial informations, and some times, I need informations about customs fields I've created with plugin.
All this fields can not appears in one views, there is no enough place for all the columns.
Damien
23 Apr 2019 21:37 #6 by babynus
Request recorded as ticket #3977
