ProjeQtOr free project management software - Quotation from Project - ProjeQtOr
20 Dec 2016 17:30 - 21 Dec 2016 16:46 #1 by antonio.grr
Hi.
In a previous Topic of mine I asked for automatic creation of Tender ( mistake !! I meant Quotation) and Bill. Now I can show you a raw code that I wrote for Quotation
In attachment a QuotationMain with some new methods.
Other minor changes in ObjectButtons.php to handle button
<?php if ($objClass == "Project") { ?>
<span id="createQuotationButtonDiv" >
<button id="createQuotationButton" dojoType="dijit.form.Button" showlabel="false"
title="Crete Quotation"
<?php
if ($noselect) {
echo "disabled";
iconClass="dijitButtonIcon dijitButtonIconCreateQuotation" class="detailButton">
<script type="dojo/connect" event="onClick" args="evt">
createQuotationFromProject(<?php echo $objectId; ?>) ;
</script>
</button>
</span>
and in projeqtor.js
It's not internationalized, many checks must be added and some fields in quotation could better set in a dynamic dialog, but it should be enough to explain my idea.
Next step form me is to create Bill from real amounts.
Best regards
Last edit: 21 Dec 2016 16:46 by antonio.grr. Reason: Attachment corretion
22 Dec 2016 10:22 #2 by babynus
Replied by babynus on topic Quotation from Project
Idea could be interesting but seems very specific to your own needs.
It seems you have one quotation / one bill per project. It is not often the case.
Also, there are many ways existing to generate Bills from projects elements, it would possibly interfere with your proposal.
I recorded the request to keep the ideas and code you propose, but not sure it will be included in community version.
22 Dec 2016 10:56 #3 by antonio.grr
Replied by antonio.grr on topic Quotation from Project
Hi.
I have to point out that I limited Quotation to one as I can't imagine to send more Quotations to client.
I'm not applying the same restriction to Bill, that will be created on Billing Type bases, using Terms and Activity Prices when applicable.Anyway, I will submit the code when it will be ready, possibly submitting Ask Topics on some points that are not evident to me.
Meanwhile,
have great holidays,
22 Dec 2016 11:04 #4 by babynus
So you never had a framework contract on a public contract...
And never had an addendum ?
22 Dec 2016 11:04 #5 by babynus
OK
22 Dec 2016 11:32 #6 by antonio.grr
You are right,but none will complain if he will have to create manually some more quotations in unusual conditions.
