ProjeQtOr free project management software - Ticket #1660 - Advanced filter on planning screen - ProjeQtOr
25 Nov 2016 18:40 - 29 Nov 2016 16:52 #1 by cmarechal
Would it be possible to add an advanced filter in the planning screen ?
it would be useful when you want to print the the main projects gantt chart of or the ones of a defined project manager.
best regards,
Chris
Last edit: 29 Nov 2016 16:52 by protion.
25 Nov 2016 18:45 #2 by babynus
No advanced filter would not be possible as it could break the WBS structure.
You can select a project to limit view to this project.
We'll try and set selection by Organization. Not sure it will be really possible (due to WBS Structure...)
25 Nov 2016 19:00 #3 by cmarechal
Bad new ...
and do you know a workaround to print only the projects of a defined project manager ?
best regards,
Chris
25 Nov 2016 19:09 #4 by babynus
Regroup his projects under one parent project, "Project of manager X".
This is not really a project but will act as you wish.
The following user(s) said Thank You: cmarechal
25 Nov 2016 20:03 #5 by cmarechal
thanks,
let's do so...
best regards,
chris
26 Nov 2016 13:56 #6 by cmarechal
HI,
I think I wasn't enough clear about my question because what I would like to have doesn't break the WBS structure.
More precisely :
-The filter would be applied only on the projects (not on their elements)
-when you applie the filter (on priority for instance) you get the projects which match with the condition AND their elements (even sub project).
-For instance, if you choose to filter through the project manager you get a Gantt view which is similar to what the project manager get when he goes to Projeqtor/Planning.
is it really hard to implement ?
It is a problem for me because when you have a meeting with your project leader you cannot have on screen the ganttview of all his projets when you are on your account. Furthermore, i cannot make a print of the main projects (ganttview) for my mayor (it would need a filter on priority)
Best regards,
Chris
