ProjeQtOr free project management software - Suggest evolution: define project priority in a list - ProjeQtOr
18 Nov 2016 18:02 #1 by mvern
To calculate multiple planning projects, it will be good to have all project in a selectable list to easily set priority on these different projects and make some try of calculation by changing priority, Hope my explanation are not too bad.
18 Nov 2016 18:23 #2 by babynus
I don't understand the purpose as long as you can define a priority for each project
21 Nov 2016 10:31 #3 by mvern
Hi Babynus,
My suggestion is not on adding priority to project but on how to manage quicker priority settings. Sometimes I need to do some tries to elaborate planning for multiple projects and for now it is not enough fast to change priority on multiple projects at a time.
21 Nov 2016 10:35 #4 by climb4fun
If I see the point properly, it looks like a request for multiple changes function on projects - priority.
Klaus
The following user(s) said Thank You: mvern
21 Nov 2016 10:40 #5 by mvern
21 Nov 2016 19:49 #6 by babynus
So you just need to use the Multiple Update feature ;)
Works fine for priority :)
Just use dedicated button (the one with double floppy disks)
