ProjeQtOr free project management software - [SOLVED] add a default offset to the "display from" field in gantt's view - ProjeQtOr
02 Sep 2016 12:50 - 02 Sep 2016 12:51 #1 by cmarechal
it would be useful to have a default view of gantt with not a beginning from the today's date (offset in the past) in order to have a better overview of the project.
This value could be set in the user setting's page.
Thanks,
Last edit: 02 Sep 2016 12:51 by cmarechal.
02 Sep 2016 12:59 #2 by babynus
This is exactly what does the "display from" in gantt view.
You just have to check "save the dates" to save the date as default.
The following user(s) said Thank You: cmarechal
02 Sep 2016 13:22 #3 by cmarechal
