ProjeQtOr free project management software - [SOLVED] directory for uploaded images - ProjeQtOr
25 Aug 2016 08:57 #1 by cmarechal
I noticed that uploaded images (to insert in a message for example with CK editor) are recorded in ../files/images. It would be useful to configure the path in parameters.php (such as for attach) in order not to lose the file when you change the version(and maybe for security problem ?)
25 Aug 2016 13:24 #2 by babynus
If you migrate the good way (overwriting existing with new) you won't loose anything.
You cannot move this directory out of web access, like it is possible for attachment.
The reason is that the editor only integrates the url to the image, so to be displayed it needs to be reached directly through browser interface.
If you need to share confidential images, just use attachments, and not direct copy in the editor.
25 Aug 2016 15:53 #3 by cmarechal
Well, I have a problem because I don't use the good migration method (I rename the projeqtor directory as projeqtor_old and I create a new projeqtor directory with the new version)
Thanks for your tip.
25 Aug 2016 16:38 - 25 Aug 2016 16:38 #4 by babynus
You should copy projeqtor directory as projeqtor_old (for a backup) and not rename it ;)
Last edit: 25 Aug 2016 16:38 by babynus.
