ProjeQtOr free project management software - [SOLVED] New report "Work plan per week and per ressource" ? - ProjeQtOr
03 Jul 2016 19:55 - 07 Nov 2016 14:32 #1 by phil-bzh
In Follow-up / Reports / planning, it would be interesting to have a tabulated report "Work plan per week and per ressource" ?
Something like "work plan per week" but with a line per ressource.
Thank you.
Last edit: 07 Nov 2016 14:32 by protion.
01 Nov 2016 21:58 - 01 Nov 2016 22:04 #2 by phil-bzh
I've done it (finally per month and not per week) and sent it to the support for a future version if found useful.
In the meanwhile => file to put in the "report" directory and to name "reportPlanProjectPerRessourceAndMonth.php" :
<?php
/*** COPYRIGHT NOTICE *********************************************************
* Copyright 2009-2015 ProjeQtOr - Pascal BERNARD - This email address is being protected from spambots. You need JavaScript enabled to view it.
* This file is part of ProjeQtOr.
* ProjeQtOr is free software: you can redistribute it and/or modify it under
* the terms of the GNU General Public License as published by the Free
* Software Foundation, either version 3 of the License, or (at your option)
* any later version.
* ProjeQtOr is distributed in the hope that it will be useful, but WITHOUT ANY
* WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
* FOR A PARTICULAR PURPOSE. See the GNU General Public License for
* more details.
* You should have received a copy of the GNU General Public License along with
* ProjeQtOr. If not, see <www.gnu.org/licenses/>.
* You can get complete code of ProjeQtOr, other resource, help and information
* about contributors at www.projeqtor.org
*** DO NOT REMOVE THIS NOTICE ************************************************/
/*** In order to add the report :
INSERT INTO `report` (`id`, `name`, `idReportCategory`, `file`, `sortOrder`) VALUES (99, 'reportPlanProjectPerRessourceAndMonth', 2, 'reportPlanProjectPerRessourceAndMonth.php', 10)
INSERT INTO `habilitationreport` (`idProfile`,`idReport`,`allowAccess`) VALUES (1,99,1),(2,99,1),(3,99,1),(4,99,1)
(il est aussi possible de modifier les habilitations à la main dans Paramètres / Habilitation / Accès aux rapports)
INSERT INTO `reportparameter` (`idReport`, `name`, `paramType`, `sortOrder`, `defaultValue`) VALUES (99,'idProject','projectList',10,'currentProject'), (99,'idTeam','teamList',20,null), (99,'month','month',40,'currentMonth')
Pour les libellés internationaux : ajouter une ligne dans tool\i18n\nls\fr\lang.js pour "reportPlanProjectPerRessourceAndMonth'
Forum : www.projeqtor.org/en/forum/3-propose-evo...ek-and-per-ressource
include_once '../tool/projeqtor.php';
$idProject="";
if (array_key_exists('idProject',$_REQUEST) and trim($_REQUEST)!="") {
$idProject=trim($_REQUEST);
$idProject = Security::checkValidId($idProject);
$paramYear='';
if (array_key_exists('yearSpinner',$_REQUEST)) {
$paramYear=$_REQUEST;
$paramYear=Security::checkValidYear($paramYear);
$paramMonth='';
if (array_key_exists('monthSpinner',$_REQUEST)) {
$paramMonth=$_REQUEST;
$paramMonth=Security::checkValidMonth($paramMonth);
$paramWeek='';
if (array_key_exists('weekSpinner',$_REQUEST)) {
$paramWeek=$_REQUEST;
$paramWeek=Security::checkValidWeek($paramWeek);
$paramTeam='';
if (array_key_exists('idTeam',$_REQUEST)) {
$paramTeam=trim($_REQUEST);
Security::checkValidId($paramTeam);
$scale='month';
if (array_key_exists('scale',$_REQUEST)) {
$scale=$_REQUEST;
$scale=Security::checkValidPeriodScale($scale);
$periodValue='';
if (array_key_exists('periodValue',$_REQUEST))
$periodValue=$_REQUEST;
$periodValue=Security::checkValidPeriod($periodValue);
$headerParameters="";
if ($idProject!="") {
$headerParameters.= i18n("colIdProject") . ' : ' . htmlEncode(SqlList::getNameFromId('Project',$idProject)) . '<br/>';
if ( $paramTeam) {
$headerParameters.= i18n("team") . ' : ' . SqlList::getNameFromId('Team', $paramTeam) . '<br/>';
include "header.php";
$accessRightRead=securityGetAccessRight('menuProject', 'read');
$user=getSessionUser();
$queryWhere=getAccesRestrictionClause('Activity','t1',false,true,true);
if ($idProject!='') {
$queryWhere.= " and t1.idProject in " . getVisibleProjectsList(true, $idProject) ;
} else {
// Remove Admin Projects : should not appear in Work Plan
$queryWhere.= " and t1.idProject not in " . Project::getAdminitrativeProjectList() ;
if ($periodValue) {
$queryWhere.= " and month>=".Sql::str($periodValue);
if ($paramTeam) {
$res=new Resource();
$lstRes=$res->getSqlElementsFromCriteria(array('idTeam'=>$paramTeam));
$inClause='(0';
foreach ($lstRes as $res) {
$inClause.=','.$res->id;
$inClause.=')';
$queryWhere.= " and t1.idResource in ".$inClause;
$querySelect= 'select t1.idResource, month, sum(work) as sumWork, ' . $scale . ' as scale , t2.id as idproject ';
$queryGroupBy = 't1.idresource,' .$scale . ', t1.idProject';
// constitute query and execute
$tab=array();
$start="";
$end="";
$prj=new Project();
$prjTable=$prj->getDatabaseTableName();
for ($i=1;$i<=2;$i++) {
$obj=($i==1)?new Work():new PlannedWork();
$var=($i==1)?'real':'plan';
$queryWhere=($queryWhere=='')?' 1=1':$queryWhere;
$query=$querySelect
. ' from ' . $obj->getDatabaseTableName().' t1, '.$prjTable.' t2 '
. ' where ' . $queryWhere." and t1.idProject=t2.id "
. ' group by ' . $queryGroupBy
. ' order by t2.sortOrder asc, t1.idresource asc ';
$result=Sql::query($query);
//echo $query."<br><br>";
while ($line = Sql::fetchLine($result)) {
$line=array_change_key_case($line,CASE_LOWER);
$date=$line;
$proj=$line;
$work=$line; //$work=round($line,2);
$ress=$line;
$val = 0;
if (array_key_exists ($proj, $tab)) {
if (array_key_exists ($ress, $tab[$proj])) {
if (array_key_exists ($date, $tab[$proj][$ress]) ){
$val = $tab[$proj][$ress][$date];
$tab[$proj][$ress][$date]= $work+$val;
//echo "on écrit $work dans tab [$proj][$ress][$date] qui prend pour valeur".$tab[$proj][$ress][$date]."<br>";
if ($start=="" or $start>$date) {
$start=$date;
if ($end=="" or $end<$date) {
$end=$date;
if (checkNoData($tab)) exit;
$arrDates=array();
$arrYear=array();
$date=$start;
while ($date<=$end) {
$arrDates[]=$date;
$year=substr($date,0,4);
if (! array_key_exists($year,$arrYear)) {
$arrYear[$year]=0;
$arrYear[$year]+=1;
$day=substr($date,0,4) . '-' . substr($date,4,2) . '-01';
$next=addMonthsToDate($day,1);
$date=substr($next,0,4) . substr($next,5,2);
// Header
echo "<table width='95%' align='center'><tr>";
echo '<td>';
echo '<table width="100%" align="left"><tr>';
echo "<td>&nbsp;</td>";
echo "<td class='legend'>" . Work::displayWorkUnit() . "</td>";
echo "</tr></table>";
echo "<br/>";
echo '<table width="100%" align="left">';
// Affichage ligne des années
echo '<tr rowspan="2">';
echo '<td class="reportTableHeader" rowspan="2">' . i18n('Project') . '</td>';
echo '<td class="reportTableHeader" rowspan="2">' . i18n('Resource') . '</td>';
foreach ($arrYear as $year=>$nb) {
echo '<td class="reportTableHeader" colspan="' . $nb . '">' . $year . '</td>';
echo '<td class="reportTableHeader" rowspan="2" style="width:40px;">' . i18n('sum') . '</td>';
echo '</tr>';
// Affichage ligne des mois
echo '<tr>';
$arrSum=array();
foreach ($arrDates as $date) {
echo '<td class="reportTableColumnHeader" >';
echo substr($date,4,2);
echo '</td>';
$arrSum[$date]=0;
echo '</tr>';
$sumProj=array();
$sumProjUnit=array();
// parcours des projets
foreach($tab as $proj=>$projet) {
$sumProj[$proj]=array();
$sumProjUnit[$proj]=array();
echo '<tr><td class="reportTableLineHeader" style="width:200px;"'.'rowspan ='.count($tab[$proj]).'>' . htmlEncode(SqlList::getNameFromId('Project',$proj)) . '</td>';
foreach($tab[$proj] as $resource=>$ressource) {
echo '<td class="reportTableLineHeader" style="width:200px;">' . htmlEncode(SqlList::getNameFromId('Resource',$resource)) . '</td>';
$sum=0;
foreach($arrDates as $date) {
$val="";
if (array_key_exists ($date, $tab[$proj][$resource]) ) {
$val=$tab[$proj][$resource][$date];
echo '<td class="reportTableData">';
echo Work::displayWork($val);
$sum+=$val;
$arrSum[$date]+=$val;
echo '</td>';
} // fin du parcours des mois
echo '<td class="reportTableColumnHeader">';
echo Work::displayWork($sum);
echo '</td>';
echo '</tr>';
} // fin des ressources
} // fin des projets
echo "<tr><td>&nbsp;</td></tr>";
echo '<tr><td class="reportTableHeader" style="width:40px;" colspan =2>' . i18n('sum') . '</td>';
$sum=0;
$cumul=array();
$cumulUnit=array();
foreach ($arrSum as $date=>$val) {
echo '<td class="reportTableHeader" >' . Work::displayWork($val) . '</td>';
$sum+=$val;
$cumul[$date]=$sum;
$cumulUnit[$date]=Work::displayWork($sum);
echo '<td class="reportTableHeader">' . Work::displayWork($sum) . '</td>';
echo '</tr>';
echo '</table>';
echo '</td></tr></table>';
Last edit: 01 Nov 2016 22:04 by phil-bzh.
06 Nov 2016 14:18 #3 by babynus
It is included in next version.
