ProjeQtOr free project management software - [SOLVED] Add EXTERNAL REFERENCE to project expense - ProjeQtOr
03 Jun 2016 10:46 #1 by jmmbb
it would be fine to get external reference in project expense. ie : we can keep link to orders (provider's number).
03 Jun 2016 11:06 #2 by babynus
Project Expense will soon evolve to get much more information than existing.
Idea is to get same detail level as the Order object.
So External Reference is planned.
Also, notion of Provider will be added.
This improvment is planned on V5.4... ;)
03 Jun 2016 14:44 #3 by jmmbb
Solved before asked !
What a good job !
As usual... :)
31 Jan 2017 11:43 #4 by StefanV
is this topic the reason, why we have the required field "external reference" in the menu "earnings - orders"?
We bought the screen customization plug in, but we can not uncheck the "required" checkbox.
Is there any chance, that we can uncheck the checkbox?
Thank you in advance.
Best regards,
Tobias Bauer (a colleague of StefanV.)
31 Jan 2017 11:46 #5 by babynus
Request has been added to plugin roadmap
