ProjeQtOr free project management software - Filters for follow-up functionalities - Ticket #1660 - ProjeQtOr
13 Feb 2015 13:53 - 23 Jun 2015 11:11 #1 by vporcelli
Filters are very useful to see only my projects for example.
But they are only available for work functionalities but not for follow-up functionalities.
they would be very useful for vue planning or project portfolio when i need to work on several projects but not with all projects.
Is-it possible to add filters for follow-up functionalities ?
Last edit: 23 Jun 2015 11:11 by protion.
14 Feb 2015 19:10 #2 by babynus
No, it is not possible to add filters on follow-up functionalities :(
for several reasons :
=> plannings display different kinds of items (projects, activities, milstones, meetings) and so have different fields : filter fileds would be a mess to manage
=> if you use filter, the WBS structure will be a mess to display (and will not mean anything if you use filter to sort items)
But what you try to do is very easy : just use the project selector on top left of the screen :woohoo:
16 Feb 2015 09:15 #3 by vporcelli
I can't use project selector because many projects are at same level (but not all) and i would like to see them together.
See all projects is quite long to to load in planning view so, i suggested add filter on planning view.
16 Feb 2015 13:49 #4 by babynus
Mayby if you want to see several projects in a glance, it is because they are somehow linked.
So possibly they should be moved under a global project (even if this entity is not really a project, but for instance some organisation splitting).
Anyway, I recorded the request as Ticket #1660.
But filters on planning screens will be limited to projects list.
