ProjeQtOr free project management software - Include Planned Overall Progress - ProjeQtOr
15 Aug 2014 19:52 #1 by francis2301
In Project Screen (and also in Today screen) it would be nice to have a "Planned Overall Progress", so could be used to compare "planned overal progress X overall progress".
Instead of planned overall progress, could also de named expected overall progress.
Kind regards.
16 Aug 2014 09:14 #2 by babynus
Already exists on project screen : expected %
18 Aug 2014 13:08 #3 by francis2301
But the field current present is automatic calculated. Differently from "Overall Progress" and the field that I proposed, where the user can choose the %.
This is useful if one is using another schedule tool but wants to use projeqtor for portfolio and store other project data/records.
regards
20 Aug 2014 08:53 #4 by babynus
The field "Overall Progress" already exists. It is not calculated.
You can select a value from list.
You can also define all values you wish in the list.
20 Aug 2014 19:46 #5 by francis2301
I'm sorry about the last post. I was unable to make myself clear.
I'm aware that "overall progress" is manually chosen and that the current field "expected" is calculated.
I'm proposing a new field, called "Expected Overall Progress", which is manually entered, as "overall progress".
Please see attached file.
Kind regards. Thanks.
26 Aug 2014 16:09 #6 by jmmbb
it seems to be a strange think that a project leader enter manually an "expected overall progress" that is different than the expected progress given by planning...
So, if you're not ok with your planning, it seems to be a good practice to review the planning either than use a specific fields...
Just my advice...
Good day
JM
