ProjeQtOr free project management software - Recording Assumptions, Constraints, Lessons Learned, etc. - ProjeQtOr
30 Apr 2014 14:51 #1 by francis2301
I'd like to propose a new functionality in Projeqtor to allow recording assumptions, constraints, lessons learned and other records.
To be simple, it could be one single form for typing the info, but this form would have one field defining if the record is a assumption, constraint, lesson learned, etc (the type would come from a list of values).
Congratulation for the great work you guys are doing.
01 May 2014 00:10 #2 by babynus
Request recorded as Ticket #1375.
It looks like some description like "Decision" would fit the need, isn't it ?
How would you call this new item ? Knowledge ? Record ? Else ?
Wouldn't this benefit of a wiki like feature ?
02 May 2014 16:38 - 02 May 2014 16:40 #3 by francis2301
babynus wrote: Hi,
1 - It looks like some description like "Decision" would fit the need, isn't it ?
2 - How would you call this new item ? Knowledge ? Record ? Else ?
3 - Wouldn't this benefit of a wiki like feature ?
Answer 1 - I couldn't understand what you mean. Perhaps you said using the currently available "Decisions" feature?
Answer 2 - I think "Knowledge" or "Knowledge Base" would be a good name.
Answer 3 - Certainly it would. I think the most important is to make sure you can search for those items (even if they are closed), because new projects could use old records as a knowledge base for planning.
Regards.
Last edit: 02 May 2014 16:40 by francis2301. Reason: making sure the proper answer for each question are linked
