ProjeQtOr free project management software - Import from MS Project - ProjeQtOr
11 Mar 2014 22:25 #1 by francis2301
Allow import activities and milestones from MS project Format. Can be a minimalistic import process like activity description, Progress %, initial date, due date.
12 Mar 2014 17:27 #2 by babynus
Replied by babynus on topic Import from MS Project
Request recorded as Ticket #1328.
Not sure it will be implemented or not :
- existing import from csv may be enough (you can easily copy / paste from MS-Project to Excel to generete cvs file)
- I always wanted to avoid bijective import / export with MS-Project as it will be a mess : as planning calculation is greatly different in both tools, export / import results will always have unexpected behavior.
13 Mar 2014 11:12 #3 by abelinux
Replied by abelinux on topic Import from MS Project
Hi Babynus! isn't it already planned in ticket #1014? (targeted v5.0) or perhaps you're talking about importing different things...
13 Mar 2014 11:25 #4 by babynus
You're right abelinux.
#1328 is duplicate with #1014.
I cancelled #1328.
19 Mar 2014 21:53 #5 by francis2301
Replied by francis2301 on topic Import from MS Project
Thank you guys. Just one last question regarding this subject:
If I import activites from CSV file (copied from MS Project), will Projector use the ExpectedProgress and RealProgress that I've imported to calculate the expected and real progress used by projector? Or do I still need to log the worked hours to calculate the real progress of a activity/project?
20 Mar 2014 13:17 #6 by babynus
No. Progress is always calculated from work.
Yes.
The following user(s) said Thank You: francis2301
