ProjeQtOr free project management software - Better usage of the system directAccess functionality throughout - ProjeQtOr
09 Jul 2013 15:57 #1 by Rexeh
This should be used as much as possible in any generated element...
An example edit to VersionDetail produces a much more interactive report than the static one currently produced:
echo '<td class="largeReportData" style="text-align: center;width:10%">' . i18n(get_class($item)) . ' #' . '<a href=' . $baseURL .' target="_blank">' . $item->id . '</a>' . '</td>';
This also applies to things like tickets with linked elements, currently you have to manually change your project (sometimes) then go to tickets and search for the ID to get more detail on what the linked element is... then go back to your original ticket.
10 Jul 2013 00:13 #2 by babynus
This can be done.
On most screens, this direct access works fine. ;)
But at first, reports were designed only for static view, to be printed.
Sure I will not go into a global redesign of all reports... :blink:
Direct link to liked item already works.
For selectoin, in most case you get a "detail" button (magnifying glass) to select item from list and if you have rights optionnaly create new ones.
