ProjeQtOr free project management software - Languages in their original translation - ProjeQtOr
17 May 2013 11:49 #1 by LEVA
I think that Project'Or RIA has a great avantage with translation, but I would like to point one think that should not be :
When you select a language, the language selection menu also translate language names.
I don't speak russian :s
I think that language should stay in their nativ translations, otherwise a newcomer can be lost and unable to change the language.
17 May 2013 12:22 #2 by babynus
You're right, I'll think about it for next version.
Luckily, unless he saves, he will retrieve previous parameter on new connection :)
17 May 2013 16:40 #3 by bel
But in the Demo for example, it's a problem.
For the Demo, I had to think that English is the first language in the list to be able to revert it from Russian or Chinese to English, I don't remember.
In Demo, Is it possible to create for example an English user profile without possibility to change AND save the language ?
20 May 2013 08:39 #4 by LEVA
I think Babynus can do whatever he wants with PhP ^^ Perhaps he only lacks time ! :p
Do you think something like :
English
French - Français
German - Deutsch
And so on with this patern Translated - Not translated
would be alright ? It suits everyone needs
20 May 2013 17:02 #5 by babynus
Not only it is possible, but it used to be operational : just a parameter that fell off once. I'll reapply it.
English
French - Français
German - Deutsch
Great idea :woohoo:
It is not what I was thinking about : it was just keeping eack language in its own language.
22 May 2013 07:29 #6 by climb4fun
Hi all,
I join the idea of LEVA. Great Idea!
Klaus
