ProjeQtOr free project management software - Lock for Tickets - Page 4 - ProjeQtOr
Lock for Tickets
11 Mar 2013 09:28 #19 by climb4fun
Replied by climb4fun on topic Re: Lock for Tickets
Hi all,
from my pov Tickets are not a requirements and scope management. Hence I wouldn't "missuse" this for this purpose.
If we have requirements, we collect them and assign them to a target version. But as every body knows, scope is dynamically and so in the course of our change management, we have to add new or to change or to reject requirements. Locking the target version is possible most of the time in a very late point of time - mostly during sign off process before go live. Locking requirements is very good as it is already implemented.
Means, for us the proposed suggestion doesn't bring any value - even it seems a good approach :blink:
Please correct me if I'm wrong.
Klaus
11 Mar 2013 12:26 - 11 Mar 2013 12:26 #20 by babynus
Replied by babynus on topic Re: Lock for Tickets
"Scope" of the project is a part of the proposal document (which is approved) and it list all the tickets selected for project
Well, yes, this is your way of working... :huh:
You are trying to freeze the scope by freezing items in it but you need first define the items list
My proposal is to fix the list, because scope is first list of items. It seems to me more accurate than "locking" tickets : with locking tickets, a ticket could be added in the scope... :(
what to do if estimates required updates?
In my proposal, treatment can be updated, and notes added ! This should cover this case. ;)
another problem you should address - what about Agile: after iteration completed there can be changes
In agile, a version should just be a sprint : short version... The complete version cannot be defined at startup (as it is agile ) B)
I think it much simpler to have an option to lock ticket description and links
I'm not sure it is the solution that will satify most situations. It is the simplest to implement but may be confusing for thoose who don't need it.
Last edit: 11 Mar 2013 12:26 by babynus.
11 Mar 2013 12:36 #21 by ekolossov
Replied by ekolossov on topic Re: Lock for Tickets
"My proposal is to fix the list, because scope is first list of items. It seems to me more accurate than "locking" tickets : with locking tickets, a ticket could be added in the scope..."
- This is exactly what I am talking: the list is fixed (and approved) but it can be silently modified by modifying the content of the items in the list (Tickets). So, you cannot add ticket because the list fixed in scope but you can modify the one of the tickets, so the scope actually will change!!!
11 Mar 2013 12:46 #22 by babynus
But how do you define the list in the tool, and be sure it is not changed ?
11 Mar 2013 12:54 #23 by ekolossov
It is in the approved document (project proposal)
