ProjeQtOr free project management software - Request: Advanced filter on same field shoult be "or" - ProjeQtOr
19 Nov 2010 14:50 #1 by climb4fun
If filtering records on same field, e. g. responsible, and adding a second filter clause then this clauses are connected with an "and". This is suitable on differend fields. But filtering same field on more than one criterion, it should be connected with or.
19 Nov 2010 15:46 #2 by babynus
Is there a real need behind this.
I explain : when selecting from a list, you select "amongst" and can select different values, and that's equal to 'or'.
When selecting on another kind of field, what is the need to have 'or' criteria on several values ?
(have you got an example on mind)
Moreover, to be able to get a "between" criteria, you have to set X >= p1 and X <= p2, then you must implement "and".
Regards.
19 Nov 2010 16:17 #3 by climb4fun
Request is to select f. e. all activities assigned to "Mr. X" and to "Mr. Y". In filter only "amongst" available. Didn't see, can select more than one value at once. Added two separate filter clauses which worked as "and", hence i got no record display.
On your reply I check multiple selection of values and it worked. Good to know.
Request withdrawn. May be a hint in filter clause window may be helpful.
Klaus
19 Nov 2010 17:08 #4 by babynus
Hint added in user manual (to come on V1.4.0)
