ProjeQtOr free project management software - Mapping Calendar to Organization Unit - ProjeQtOr
07 Sep 2022 16:21 #1 by ravindra.gullapalli
At present, calendars can be mapped to the resource.
However, if we can map calendars to the organization unit, all resources in the organization unit can use the same calendar and it will be used for project planning.
If a resource has a mapped calendar, it will be used in project planning instead of the one mapped to the organization unit.
08 Sep 2022 11:22 #2 by babynus
As described, this would require major change as Calendar is actually required for resources.
NB : you can easily change calendar for several resources with multiple update.
23 Sep 2022 09:13 #3 by sharky
I agree with the idea.
Have an agenda by
- project(s)
- by multi resources
- resource group
- Teams
- units
