ProjeQtOr free project management software - Sorting projects and sub-projects - ProjeQtOr
15 Feb 2021 13:05 #1 by pakkes
Hello.
I would like to propose a little evolution on your awesome software, in order to optimize the job time.
In first, I would find usefull to sort sub-projects by name on lists, instead of the actual sorting mode.
Then, I would like to specify the way your software sorts the whole list of projects on main projects view (by name for example ...). This in order to reduce the time to visually identify a project row among hundreds of rows.
Eventually, having both features configurable would be really usefull.
Many thanks.
16 Feb 2021 12:58 #2 by babynus
Actual sorting is the WBS order. And this won't be changed.
So you just have to reorder the WBS of your sub-projects to get the order you want.
Just define a filter with the sort order you wish (and no specific filter), save it as stored filter, and set it as default filter.
16 Feb 2021 16:15 - 16 Feb 2021 16:16 #3 by pakkes
Hello.
Many thanks for your detailed reply. I'd forgotten there is the possibility to sort projects and sub-projects on "Projects portfolio".
Many thanks for your help.
Last edit: 16 Feb 2021 16:16 by pakkes.
