ProjeQtOr free project management software - [SOLVED] Workflow : explicit help from popup for accelerator - ProjeQtOr
24 Feb 2020 12:21 #1 by jmmbb
when you use accelerator for workflow, help popup give you information like "set status to ..." that's not a great help because you can read the same on the accelerator button.
What about using a field in status to explain the sense of status (like "validate budget usage for the expense") that is used to help user when using accelerator ?
Then, you will have "validate budget usage for the expense" in the popup instead of "set status to validated", that is more explicit.
Expect to be clear.
regards,
24 Feb 2020 21:35 #2 by babynus
Understood !
Ticket #4513 recorded : Add dezcription on "Next status" button
1) On status screen : add "description" feld
2) On "next status" button (button on right of status list), show descrition in tooltip (instead of "set to status xxx")
