ProjeQtOr free project management software - Clone Environtment - Only for selected projects - Page 2 - ProjeQtOr
04 Feb 2020 14:04 #7 by babynus
Not sure the data cloning environment will be any help.
If you want a snapshot, youi want something that we not be updatable after copy.
This is not the case of data cloning environment that are designed for simultaion purpose, so data can be changed in Cloned environements.
Maybe a backup of your DB or snapshot of VM will do the same.
But, IMO, CMMI does not required to have a "snapshot" of all data.
It will require to be able to check how many items ware active at a given time to be able to produce indicators..
This can be easily done with history (at least more easily than trying to copy the envisonment)..
The following user(s) said Thank You: javierrm
13 Feb 2020 15:01 #8 by javierrm
In our procedures of CMMI we have since a baseline will be saved (with the requirements, risks, problems, activities, etc.) that can be consulted at any time to see the status of the process at a specific time in the project.
I have made some minor modifications to its environment cloning tool, and so if in the general project drop-down you have chosen all the projects, you make a cloning like the original one, if you have a selected project, you make a cloning of the selected project ( I have not been able to filter the copy by that project, so I had to delete the rest of the projects from the tables after copying everything), leaving this environment copy in read only in order to save a complete baseline of the project.
I hope you do not mind that you have made these changes and I send the files with changes in case you want to use them in the future.
13 Feb 2020 15:02 - 13 Feb 2020 15:03 #9 by javierrm
The files.
File Attachment:
File Name: DataCloning.zip
File Size:16 KB
Last edit: 13 Feb 2020 15:03 by javierrm.
14 Feb 2020 15:20 #10 by babynus
Hi
Thanks for sharing your work.
Not sure we'll integrate it, as it is not DataCloning any more, it is "backup of a project".
